albertaflyer
Active Member
Just wondering what would cause a fuel pressure drop. I have an o360 with the stock mechanical pump and a faucet boost pump. What would cause it to lose pressure (down to .5 psi) even on the slightest of nose up attitude (without boost pump on)? Even with full fuel it still will drop unnervingly low! If i turn the boost pump on it will climb back up to about 5 psi. The engine has never stuttered or missed but I would just like to know what may be causing this. There is a tee after the mechanical fuel pump, one goes to carb the other to a remotely mounted sending unit on firewall... Any ideas? Is it because the mechanical pump is sucking the fuel from quite a distance and through quite a few restrictions (fuel selector, elbows, fuel pump that is not on)
