Frogman208
Active Member
Hey guys,
Just replaced my Dynon transducers with the updated Kavlico models, so I've been watching fuel/oil pressures. I've got the standard Bendix RSA-5 setup on my IO-360 A1A. I've updated the Dynon engine maps and put a couple flights under my belt with all pressures looking good while in flight. However, this is the first time I shut the engine down but kept one of the Dynon screens on for about 30 seconds and I watched the fuel pressure slowly climb to around 50psi
. If I push in the mixture from ICO it drops to zero and slowly rises again. Since I put all my flights on SavvyAnalysis I went back to check on flights prior to changing out the tranducers. I was able to catch some flights that showed this same trend for a few seconds before the Dynon EFIS shut down. My "***"umption is this is normal due to heat soaked engine increases vapor pressure in the lines. Keep in mind, engine is completely shut down, no pumps operating (mechanical or electrical). I hear the usual vaporization in the lines under the cowling when I open my oil door but that much pressure reading off the transducer? Thoughts? Normal? Abnormal? Can it blow the diaphram on the mechanical fuel pump?
