More QB Info
I built a QB, which is now flying, and I can say the nuts were very loose, but I went over it carefully and even upgraded to the screen type tubes. The day I installed the tubes and sealed the covers was the day that went on "forever", but because I remember that day so well, I know they are tight. I agree that
ALL QB guys that don't remember tightening the nuts should check. As for the other guys, I don't think that it is really justified if you are sure you got your nuts tight.
The following is what I finally got back from Tom Green at Van's:
VAN?S AIRCRAFT, INC.
14401 NE Keil Road, Aurora, Oregon, USA 97002
PHONE 503-678-6545 ? FAX 503-678-6560 ?
www.vansaircraft.com ?
info@vansaircraft.com
2-27-06
Van?s Aircraft has received several questions regarding alternative means of safetying the fasteners affected in SB 06-2-23 (Safetying the Fuel Pickups). While the methods called out in the service bulletin are not the only means to secure these fasteners, Van?s Aircraft feels that they are the best option to achieve the intended result. Van?s Aircraft Inc. does not intend to evaluate or recommend other options.
Service bulletins for aircraft operated under Part 91, regardless of how they are named (mandatory, required, optional, etc.) are issued by the manufacturer and, legally speaking, are advisory only. Service advisories are required for Part 91 operators only in the form of AD?s.
Van?s Aircraft issued Service Bulletin 06-2-23 in the interest of safety. If even one builder has neglected to properly install and torque these fittings and this service bulletin prevents an accident, injury or death, our mission is successful. We apologize for the inconvenience but stand firm in our diligence to safety.
