lockeed
Just did a quick flight were - a couple minutes after refueling and takeoff - I could see fuel coming out from the left fuel tank cap
not a great sight.
Came back safely. After inspection, I found that I could turn the cap, even when locked into position. I was told to try and tighten the screw at the bottom but I broke off the small cuter pin inside the lever on top...![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm trying to figure out if I should just replace the pin and try to tighten the nut at the bottom - and try to make it close tighter...
or
Just get two new caps...
Kit is from mid 90's, but the plane was completed last year - and is almost new with 85hrs.
Cap's appear to have the correct brown type seals.
or
