J Jimzim Well Known Member Nov 2, 2012 #1 Just curious, is the wire from the Van's float type fuel gauge a power or ground? Thanks, Jim
Mike S Senior Curmudgeon Nov 2, 2012 #2 The sender is internally grounded, so I guess the answer to your question is yes, the wire from the gauge to the sender is ground. Buss power to the other side of the gauge.
A aerhed Well Known Member Nov 2, 2012 #3 The wire goes to ground through the float sender which varies the resistance to ground.
