My left Van?s fuel gauge works fine with master switch on but recently now goes dead after I start the engine. I?ve checked for loose wiring etc. Any ideas on where to look would greatly be appreciated. Thanks
If you cycle your master off and back it will maybe come back on.
I know mine do that sometimes when my battery is getting weaker. I think they have must have circuitry that cuts them off when the voltage drops too low.
In my setup I turn on the "E-BUS ALT FEED switch while cycling the master off and on to keep from recycling everything.
