Guy at garmin clueless. Thx dm
Ok thx. The garmin guy was basically an answering machine as most of the others at Oshkosh.You asked the wrong guy then... Try [email protected]. If you're talking regular float type senders then yes. Two wires, a ground, and a signal from the brass screw at the end of the tank.
Finally got a look at the floor between fuel selector and firewall and realized no room for transducer to sit. Not deep enough. Did not get a look directly behind selector, as there may be more room (depth) Has anyone mounted in this area? If not they'll mount fwd firewall and get a couple hoses fab'd. Thank you. DM
