The plans specify "high temp" adel clamps for mounting the transducer. Van's sent me regular clamps in the required size.
Has anyone else run into this issue. I would have called Van's but they're closed today and I'd like to get past this.
Thanks in advance
The important requirement is that the have stainless steel bands (not aluminum).
The ones you got in your kit should be stainless steel.
Part number supplied is "MS21919WDG26". Plans specify "MS21919WCH26".
The WCH is a stainless steel clamp.
That is what should come in the kit.
I suggest you contact the office on Monday
