Fuel Injection Flow testing
As a field engineer, and having just done this on my RV-9A project, this my suggestion for fuel injection system flow testing:
Once the fuel system is intact, it needs to be leak checked and verification of proper operation.
The following items should be checked before first engine start:
• Fuel fitting leaks (both pressurized and static head pressure with pump turned off. The static leak check is important on the suction side of the electric pump, because with the pump running, the suction side is less than atmospheric pressure and a leak may not appear until the pump is turned off; trust me, I know this first hand),
• Fuel pp discharge pressure as expected,
• Fuel flow check, both, open end free flow and flow verification through the FI servo.
• Functional verification of the Throttle and Mixture controls.
Open end flow test:
Disconnect the fuel line at the FI servo inlet and run an extension tube to a gas can.
Turn on the electric fuel pp and flush several gallons through the system. Discharge pressure may only be 1-2 psi, but flow rate should be in excess of 35 gph. Determine flow rate by known fuel quantity over measured time. This should agree closely with your fuel flow transmitter if installed.
FI Servo flow test:
Because fuel flow through the FI servo is restricted with no airflow to regulate the fuel, you can not actually test full rated flow through the servo. However, a minimum expected flow can be verified.
• Disconnect the fuel line going into the FI distributor, as there is no need to actually charge fuel to the cylinders. Run extra tubing for the fuel to a gas can.
• Push the Mixture control full rich position and Throttle full in.
• Start the electric fuel pp and verify the following:
o Fuel flow present, pump primes and pressure is stable between 25 to 30 psi. Check fuel flow is about 4.5 gph. (This is the max amount without airflow through the servo).
o Pull Throttle out to Idle position and verify fuel flow reduces to minimal amount (about 1.5 gph). Fuel pressure should remain stable between 25-30 psi.
o Push Throttle full in, verify about 4.5 gph returns.
o Pull Mixture to Idle Cut Off position and verify fuel flow stops and fuel pressure remains stable.
