I bent my sender wire for left tank using the approx 3 inches on the plans, but I'm not happy with the range I'm seeing on the float. I searched and found a post saying it should be more like 3-1/4 inches per arm, so I would like to make another. Does anyone know what wire I can use to make this from? Anything special about it? Just plain steel wire of the proper diameter?
