Searched previous threads for a while but couldn't find a good answer.
I have a question regarding bending the float arm wires with regard to QB tanks. Reading the instructions/plans they have you bend the arms and check that the float makes it to the specified distance from the top and bottom skin and then adjust as necessary from there. That's great if you have a standard build tank and the T-702 rear baffle is not yet installed. For those of us with QB tanks can I assume that if I bend the wire to the dimensions provided that it will be close enough and any further tweaking can be done in calibrating the EFIS down the road?
