Rodney
Active Member
Good day,
RV-7A. Not the builder and looking for the fuel filter.
Not in tunnel between seats and firewall. I?ve checked between fuel selector and elec fuel pump mounted on firewall in the tunnel.
Also not in engine compartment between electrical fuel pump and gascolator
Where else should I check?
Rodney
Is it a carbureted engine?
If so, then the gascolator you mentioned having, is the fuel filter. It should have an internal filter screen.
The Facet pump installation instructions say it is required to have a filter before the pump. I installed mine in each wing root at the tank as I didn't want to have to check and clean a filter in the cabin. I also have a gascolator on the firewall as required in Canada.
pickups
There should also be a screen on the ends of the pickup tubes inside each fuel tank to prevent any coarser particles from getting into the fuel lines.
Copy all-thanks!
Thanks for the input!
I looked in wing roots-no filter so seems the gascolator is in fact the filter.
If the engine pump fails, we depend on the electric pump; suppose we are assuming it won?t be contaminated that day.
Such is life
Fly safe
Rodney
Such is life
Fly safe
Rodney
Don?t fret it. My carburated Piper Archer only has a gascolator, too. 46 years without a problem. :cool:
