Jimzim
I am installing an Ellison Throttle Body on my 0-360 powered RV 7. Ellison recommends a 70 micron filter. I am using a standard Van's setup, including Van's gascolator. Does anyone have a recommendation of an additional inline filter I should use, or am I good to go, as is? Right now, I am going straight from the gascolator to the pump. then to the ETB.
Thanks, Jim (dues paid)
Does Ellison sugest where in the system the 70 micron filter is to be? Possibly after (downstream) of the pump?
Bevan
