rickmellor
I'm trying to figure out if there's a discussion forum for Advanced Flight Systems' EFIS. There are groups for GRT, Dynon, MGL and BMA but I can't find one for AFS. Anyone have a link?
-Rick
-Rick
rickmellor said:I'm trying to figure out if there's a discussion forum for Advanced Flight Systems' EFIS. There are groups for GRT, Dynon, MGL and BMA but I can't find one for AFS. Anyone have a link?
-Rick
rickmellor said:I think the best approach is to have an open forum that is hosted by the company (official forums). Companies shouldn't censor the posts but should monitor / participate heavily in the discussion (e.g., Dynon, BMA). I haven't followed the MGL forum but I'm sure you guys are quite active there as well.
-Rick
cbnank said:MGL Avionics!
I apologise, but I do not know MGL, but I am almost ready to buy my avionics and I would like to know how to contact your company for information. Can you give me your web address?
Carl Nank
[email protected]
About an inch to the left of your postcbnank said:snip.... but I do not know MGL, but I am almost ready to buy my avionics and I would like to know how to contact ...snip
N401RH said:Our new facility will enable us to better serve our customer?s needs and enable us to dramatically increase production of our avionics product line. Our new 7,500 sq-ft facility is......
LARCO said:I beleive their system doesn't rely on the pitot for the horizon. Larry
Is this because you are using three angular rate sensors and not a mechanical gimbal kind of thing? I'm just curious to how it actually work.Rainier Lamers said:...
The correct term is "aiding". What it means is to use sensor measurements other than gyro "rate of turn" and acceleration measurements to figure out how you are related to the Earth surface level. What we are trying to do in particular is to somehow remove the apparent errors caused by accleration on the horizon view derived from the accelerometers to get a vector on Earths gravity.
SvingenB said:Is this because you are using three angular rate sensors and not a mechanical gimbal kind of thing? I'm just curious to how it actually work.
gmcjetpilot said:A SIMPLE EXPLANATION OF INERTIAL (GYRO) NAVIGATION SYSTEMS
The equipment, and hence the aircraft, knows where it is at all times. It knows this because it knows where it isn't.........
. However, it is sure where it isn't and knows where it was. It now subtracts where it should be from where it wasn't ( or vice-versa ) and by differentiating this from the algebraic difference between where it shouldn't be and where it was, it is able to obtain the difference between its deviation and its variation; this difference being called error.
It's a joke but not to far off.
