Ok, here's the story. seems that this time i really need some help:
as you all know the lycoming baffles are attached to the engine via several bolts, some at the cylinders and some at the crankcase. one of these bolts is located right behind cylinder #3 and very close to that funny hole that is there to house a black plastic tube thing where you screw in your oil dipstick. maybe some of you now suspect what happened...
i tried to final attach the baffles today. to get access to that aforementioned phillips screw i removed the black oil dipstick tube and wanted to get the bolt into the hole. then a heared a noise like this... bling, ding, ding, dong.
thing is that one bolt, one washer and one lockwasher are now not where they supposed to be. these suckers where falling through the dipstick hole and do now hide somewhere inside the crankcase.
if you should sympathize with my problem, you are maybe willing to answer the following questions.
1. is that an issue? (i guess yes)
2. if yes... any idea on how to remove the FOD?
3. why do strange things always happen to me?
best wishes from munich-germany.
Kay Stecklum
RV-7 still in progess
PS: just determined 10 minutes ago that my fridge was running out of beer.
Kay Stecklum
