Sly-Tec Starter Questions
I've got a sky-tec starter on my RV-6 with a Lycoming O-360. I have 230 hours on the plane and started with a new engine. Two times recently it back fired and caused the engine to turn over backwards and spin the starter in reverse. I think I may have let go of the starter switch and it fired at that point and caused it to reverse. I checked my ingition switch to make sure it is starting with only the left mag energized and it is. Then recently I also noticed that after starting it sounded like the starter bendix was still in for a moment or two. So I pulled the starter to check it out. I figured maybe the bendix needed lube. It was perfectly clean and worked very smoothly. I lubed it up anyway and clamped it in a vise. I hooked up jumper cables and spun it up. The bendix comes out instantly when applying power but stays in when I pull off the cable until it slows down. It is as though the motor is running as a generator and powering it enough to hold the bendix in. Is this normal? Also why do I have a starter solenoid on the firewall and a second one on the starter? The one on the starter is jumped out to energize when the firewall one is on. Couldn't I just use the one on the starter and eliminate the firewall solenoid? It would seem that would eliminate the solenoid staying in problem, I think?
