BoilermakerRV
So, I'm just about to assemble my aft fuselage for the first time. The instructions would have you mark the center line of the J-channels. I assume this line will be used to center the J-channel on the pre-punched holes of the fuselage skins. I've noticed that the channels are not perfectly straight. I assume this is an artifact of putting the J shape into flat sheet.
Has anyone fluted these to straighten them out, or does everyone just pull them into alignment in assembly.
Thanks!
Thanks!
