miyu1975
So my last task tonight was to flush the fuel lines. I am hoping to make the first engine start on Monday. I put 4 gallons 100LL in each tank, disconnected the fuel hose that in connects into the Bendix FI coming of the mechanical fuel pump. Then master on, boost on....expecting fuel to flow nicely into the bucket I set up..but nothing. I tried several times and the let the pump go for about 10 seconds. Never did get anything. I am using the EFII pump. Do I need to prime it somehow since this is its first use? and how if so..??
