Hi all,
I've learned a lot about sheet metal and rivets, etc., but still have much to learn about fiberglass.
I am repairing some mis-drilled holes in my wheel pants. Is it an acceptable repair to mix some epoxy & filler and use that to fill in the holes if the correct holes will later be drilled about 1/4" away?
Should I use balloons (what I'm familiar with) or flox?
Thanks for any pointers,
-dbh
-dbh
