A asw20c Well Known Member May 22, 2017 #1 I'm not considering it, but has anyone ever seen an RV on floats? Is is possible?
rvbuilder2002 Legacy Member Mentor May 22, 2017 #2 asw20c said: I'm not considering it, but has anyone ever seen an RV on floats? Is is possible? Click to expand... Google search photos for - RV-6, floats You should find the two (a 6 and a 7) that are most well known. There have been at least a couple of others.
Greg Arehart Well Known Member May 23, 2017 #3 I believe there was a 9 built in Alaska with floats. Big downsides: much more drag/slower speeds/higher cylinder temps etc. Low-wing airplanes are not very easy to dock on floats (how many other low-wing float planes have you ever seen....).
n5lp fugio ergo sum May 23, 2017 #4 Eustace Bowhay I think Eustace was the first. I'm sad there are so many who don't know about this key person in the RV community.
rvbuilder2002 Legacy Member Mentor May 23, 2017 #5 Greg Arehart said: (how many other low-wing float planes have you ever seen....). Click to expand... Not many, but there are a few unusual ones....
