For those using a GRT engine Monitor and a carb engine - Where are you mounting the flo scan unit for fuel flow? Does it have to be before the fuel pump or after? I have seen some sites where it is mounted after the pump and with the fuel pump on the firewall, the options are few and far between here. Andy Karmy (RV-9A) has a slick set-up but my electrical runs will not allow his config on my plane.
Has anyone moved their low pressure pump back towards the fuel selector and mounted the flo scan after it on the floor like some of our fuel injected brethren? I believe the -6's have their fuel pumps back farther from the firewall as well.
Opinions?
Jeff
Opinions?
Jeff
