pa38112
I am installing my new ADS-B equipment and would like to receive the audio alerts. I have a Flightcom 403 intercom with no audio panel (only one Com radio). I do have a Music radio. I am not sure if I should wire the audio alerts into the music input in parallel with the music radio, or can I wire them into the Navigator mic. input? - It is a 2 place plane, so I am only using the pilot and co-pilot inputs currently.
Any advice or suggestions would be appreciated...
AP-60 Audio Mixer
You may wish to consider our AP-60 Audio Mixer designed for this purpose.
http://www.fdatasystems.com/ap-60-audio-mixer/
Chuck Newman
Flight Data Systems
VAF Advertiser
Don?t use the mike input, it?s designed for lower level signals.
Put a 330 or 470 ohm resistor in series with the music input line. Do the same with the adsb warning audio line. Then tie them together and insert into the music input. If one or the other is too loud, increase the value of its resistor.
