FutureRV
Member
I have a RV-7. Looking for a alternative to the straight control stick shaft. Is there one available that curves aft? For example the RV-14 control stick has a curve..
Why? If it curves aft, you will likely run out of room before running out of ?travel?. The RV14 likely has different cockpit layout requiring the bend.
Bevan
Bevan
I find that if the control shaft just had a slight aft bend, it sould allow my hand to sit on my lap in a more comfortable position. Sounds like that is not available at this time. Thanks for the input.
