Thanks Kevin. So do you think it would be wise to set maximum travel to about 30 degrees to keep myself out of trouble? If these went full 40 degree flap by mistake would it drop like a rock?Just want set some safe margins.
Mike Seager taught me to use half flaps on the downwind by holding the switch down for a 4-count. On base, go ahead and use full flaps.
Mike Seager taught me to use half flaps on the downwind by holding the switch down for a 4-count. On base, go ahead and use full flaps. He explained that half flaps improve lift; full flaps give you the drag you need to slow down. This ain't a Cessna.
Jim Bower
RV-6A N143DJ
