I'm attaching my flap motor and the sensor for flap position behind it. Can someone send a pic of the flap actuator at the max extended position? My sense of it is if I put the sensor at the lowest position in the screw slots it will be right when calibrated later..... It is harder to get a screwdriver on it later though when the actuator is bolted in all the way.
And thank goodness I put the sensor in now instead of later. I'd hate to have to pull those flap tubes out again....
