lostpilot28
This is the second time it's happened. I was flying today, inbound for landing...started my procedure to drop half-flaps, and I got nothing. Basically landed flaps up, no problem. Same thing happened about 2 months ago.
I checked the fuse after each incident and it was fine. The first time it happened I decided to troubleshoot the problem the next weekend, but when I showed up that day the flaps worked.
Fast forward to today, after hangaring the airplane I checked the fuse. It was good. Looked at all the wiring under the panel, even gave them a light wiggle while activating the flap switch. Nothing. So, I decided to give a nice hard "thump" to the triangular brace where the flap motor resides. Activated the switch and the flaps now worked. Hmmm!
I really don't believe it's a wiring problem. My guess is the motor is failing. Anyone else have this happen? Any ideas? When it runs, it seems strong. Maybe it has an internal "intermittent contact" problem.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
