Steve Brown
Flap linkage jammed
Just got back from a trip to Co (KAPA). Twice on the trip I had the experience of thinking the flaps were all the way down, but they weren't.
On landing KAPA I didn't notice until I was on the ground. Landing KTPH for fuel on the way home, I noticed when on final the airplane was gliding forever and then finished lowering them.
In Colorado I was a little annoyed with myself for an apparent lapse of following pre-landing checks. at Tonapah I was very concerned that I had become a lame pilot.
At the end of the trip landing at RHV when I went to put the flaps down on final they didn't budge at all. After a few moments of denial I readjusted my strategy for no flap landing.
When I dug into the problem yesterday I found that the linkage at the flap actuator weldment was completely jammed. No play, wiggle, or movement. It looked as though the safety wire had caused the jam. I guess during the two partial flaps incidents I heard the moter run, including the sound of it hitting the stop (so I thought), glanced to see they were "down" and assumed they were all the way down. Obviously this procedure has holes in it which I need to plug.
Anyway, see DWG 33, DETAIL E
I think there were only two washers in the assembly. It is possible I lost one in the tunnel, but I searched carefully.
Here is some confusion with DWG 33:
Left side view, area detail E calls out 3 washers
The exploded isometric view shows only two washers
Detail E doesn't mention any washers
When I reassembled it, I noticed that the flap actuator fell naturally to one side of the flap actuator weldment, so I put two washers on one side (pilot side).
Also, I didn't wire it as shown in detail E, because I thought that was the source of the jam. I put the safety wire hole in the flap actuator rod facing
aft, and put the wire around the pilot side tab on the flap actuator weldment. Pictures below
Cycling the flaps down and up, everything seems to work fine. The safety wire seems to not be in position to cause another jam or fatigue when cycling the flaps.
I guess I could wire it as shown in the plans and replace one of the washers with the wire. I'm reluctant to do so because I think that was the source of the jam.
Any comments on this?
Picture quality a little poor, but I think good enough:
![1.jpg](/community/proxy.php?image=http%3A%2F%2Fwww.brown-web.net%2FFlying%2Fflap_repair%2F1.jpg&hash=f08f295e60b23894cae57ff8c50759cd)
![2.jpg](/community/proxy.php?image=http%3A%2F%2Fwww.brown-web.net%2FFlying%2Fflap_repair%2F2.jpg&hash=cc6390b55f43c40aabb2db57b0ea3709)
![3.jpg](/community/proxy.php?image=http%3A%2F%2Fwww.brown-web.net%2FFlying%2Fflap_repair%2F3.jpg&hash=0573960caec76905fbcb157d0455047f)
![4.jpg](/community/proxy.php?image=http%3A%2F%2Fwww.brown-web.net%2FFlying%2Fflap_repair%2F4.jpg&hash=e24edd651aa1011c6aca09946d19285b)
![5.jpg](/community/proxy.php?image=http%3A%2F%2Fwww.brown-web.net%2FFlying%2Fflap_repair%2F5.jpg&hash=e776b89e0a9a29be9fb4b42d64d2057d)
