777Dave
Have been considering electric flap conversion for a while but really don't mind the manual flaps except that I have discovered that sometimes when I take full flap, even below 80 mph, the handle doesn't fully engage into the notch on the side of the seat. After playing with it on the ground for a bit, I can see that when there is an air load on the flap, you have to pull fairly hard to extend them and in doing so the handle tends to twist enough that the bottom edge doesn't enter the slot...somewhat uncomfortable feeling.
Has anyone reinforced their handle to keep it from twisting? Seems like I may try that starting right at the base of the handle itself. Comments?
