ariel_arielly
Active Member
Hi.
I want to install the Christen 801 Inverted Oil System to my RV8A, equipped with the Lycoming XIO360-M1B engine.
What fittings should I use?
Ariel
RV8A S/N 80295
4X-OAA
(ISRAEL)
Ariel---you'll be using -10 AN fittings and hose. Where you mount the tank will determine what those fittings will be.
Tom
Ariel--it may vary from install to install, but AN816-10D, AN822-10D, AN823-10D. AN816-12D for the top of the tank.
Tom
Christen docs are ok. I found good info on an acro forum just by googling exactly your query terms
