I'm fitting the Dynon wiring harness and cannot get the connector to the co-pilot's control stick to reach. Does anyone have some images I can look at or check mine to see if there is anything I've miss routed.
I think I have the main harness correct as it leaves the avionics bay. I can't clamp it as the mounting plate for the clamps come in the engine kit. It seems to be about 4 or 5 inches short even after I tried pulling back some of lacing.
This is the wire exiting the avionics shelf
Then the side of the plane showing the connector short of the cutout it should go into
This the wiring under where the throttle quadrant will be
