Jeff R
I have an IO-320 with a fixed, metal Sensenich prop. I was trying to fit it today to the engine to do some fittings, but I cannot get the prop extension to mate fully with the properller. Even with some lubricant and gentle tapping with a rubber mallet, I can't get the guide pins into the prop holes. Before I start tapping harder I thought I would check to make sure this is indeed a very tight fit that takes a LOT of tapping with a mallet.
Thanks.
Thanks.
