spaceflightmeow
Active Member
Below you see the outcome of my first time priming with an HVLP sprayer.
I've made a mess of priming my first wing parts. I have a few thick runs and a few bald spots.
![](/community/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FkO9n2Co.png&hash=291b03d6beece920d56418b893aacbc4)
The question is, how do I best clean and prepare these parts for priming again?
I want to at least remove the thick runs. A friend suggested to soak parts overnight in some strong solvent (maybe MEK or Acetone) to get all the primer off, and re-shoot again.
Also, I would appreciate any advice on how to set up for priming. (I'm in the process of searching the forums and internet...)
Background: Done with a Harbor Freight HVLP gun, 40 psi, 1.5mm tip and Sherwin Williams DTM Wash Primer. The primer instructions say to prep parts with non-petroleum-based solvents and clean the sprayer afterwards with water (EDIT: On second read, the data sheet says to clean up with mineral spirits). I washed and lightly scuffed the parts with a dish Scotchbrite sponge and dish soap.
I propped the parts up against a wooden shipping crate and sprayed a first coat. That first coat came out clear. Puzzled, I waited 20 mins and realized I didn't mix the primer, so I mixed it and sprayed again. I then waited about 30 mins and saw some bald spots, which I sprayed again. Waiting about 8 hours, you see the result above.
Lessons for next time are that I'm putting on too much primer, and that the parts should be hung on wires since resting parts against a surface allows overspray to run and pool onto the parts.
