While it is perfectly acceptable to wipe away excess proseal with MEK, I am not aware of a single manufacturer that approves thinning it with MEK. Indeed, you will likely find they caution against doing so. I base this understanding on years of applying proseal on new manufacture military aircraft. I am told that the only acceptable thinning material on non-military aircraft *may* be toulene in very small amounts, but I've never followed up on that to be absolutely certain though. In any case I have never run into a single situation in which thinning proseal is even necessary. One way or another, I'd contact the proseal manufacturer before I'd start messing around with its chemical properties on an ad hoc basis.......you can add MEK while your mixing it (MEK is in proseal) to "thin" out the mixture.....
How many clecos do you have? Photos here can show you how it is possible to seal all the fuel tank ribs without smearing the sealer and in a relatively mess free, trouble free manner:......Next, the ribs... they should be a bit more "interesting" ............
http://www.vansairforce.com/community/showthread.php?t=7602
not sure how much of a real issue it is but you have formed a bit of a dam around your tank drain that may prevent some of the accumulated water from reaching the drain. i copied what others have done to provide channels to the drain...
