wow riveted and sealed my first rib in the left tank what a lousy job i did
my rivets are sitting higher than id like. they appear tight and i believe sealant is everywhere it should be.
any tips on a better riveting job the stiffeners and fuel filler were easier with back riveting but also not as good as all my previous rivetting
im using a mushroom set with a rubber ring compressor down to 45lbs
ill take any advice
thanks in advance
ill take any advice
thanks in advance
