DeltaVee47
Active Member
Good morning
We flew N557GB for the first time yesterday-twice actually.
The plane flies perfect straight and level hands off. A real testament to the Vans folks that a rank amateur can assemble a plane that flies great right off.
Two questions
1)The manifold pressure was reading about 30 inches on takeoff where I was expecting maybe 28.5 at sea level. I do not see that there is a calibration ability for this in my G3X touch system. I have dual p mags with a tee junction for the MAP tubing. Could a slight restriction somewhere cause this reading or should I look elsewhere?
2)I love the sensitive control inputs but pitch seems almost too sensitive and when I put the nose down and speed built up the control forces became very heavy. I reduced power to avoid pulling too hard. Normal for this bird? I actually hope so and I will learn to use the touch of a surgeon.
Otherwise perfect flight. We found nothing amiss under the cowl after so we buttoned up and flew again because why not?
Thanks everyone for this and all the support over the years
Greg Beckner
Two questions
Greg Beckner
