My first flight was this evening. With the exception of a problem of high CHTs, the engine ran smoothly and the airplane performed nicely.
Photos:
http://www.c-func.com/album.html
Video:
http://www.youtube.com/watch?v=JA3v69GY2j4
Now, the CHTs are concerning me. Here's the data:
Overhauled O-320D2A from AeroSport with new ECI cylinders. The engine was run-in for about 1.5 hours at aerosport, and my initial ground runs did not take more than 0.1 hours total. Fixed pitch catto prop.
Flew at about 1500ASL (~1000 AGL) for about 1 hour. It was quite warm outside. Ran full-rich the whole time.
Oil pressure and temperature steady at about 70 and 212-215 respectively.
With power around 2300RPM, the CHTS were all very close in the 425 range. Whenever I ran it at 2400RPM or higher, the CHTs on all the back to cylinders crept up to around 430. Manifold Pressure was about 29".
If I powered back below 2300RPM, the CHTs would fall off to around 405.
I had wheelpants and leg fairings off and was only making about 120-130 kts.
I didn't like the high CHTs but I felt it was important to keep the power up for hte break-in. So I ran it with the CHTs in the 420s, and when the temps crept much over 430, I powered back to cool them back down closer to 400, and then increased power again until the CHTs crept up over 430 again. I ran like this for a total of about 1 hr.
Questions:
1) Should I be worried?
2) What should I do?
Photos:
Video:
Questions:
