Hi all completed my first flight this weekend everything went ok. I have a problem and need your help. RV-9A,0-320-E2D, with AFS 3500 EE. The engine starts good, idles good, mag checks good and smooth @ 1500RPM. takeoff climb is smooth, #3 cylinder temp was a little high about 430 but comes down after leveling off to below 400. I glassed the opening of the inlets today will see how this does. But heres the problem when I level off and pull throttle back to 2400 or 2500 RPM the engine surges about 10 RPM according to the engine monitor tach. You can here and feel it at all RPM.
It does it at lower RPM as well, just slower surging. Boost pump has no effect, switching tanks has no effect. I have replaced the carb gaskets used a little RTV on them, removed oil seperator, checked all fittings for leaks, see no leak on engine(fuel or oil), timing @ 25 BTDC. I do believe it is fuel related just not sure what. I will talk with Bart tomorrow and get his help. I may have forgot some details as i write all this and I have flown it three times now and it does the same thing every time. I forgot running three blade catto prop. Any idles? Thanks.
