With the VM-1000C in particular, you need to make sure the "ignition type" setting in the box matches your ignition type. The Vision people told me the only thing that setting does it tell the unit whether to look for one pulse per revolution or two.
The VM-1000C and the VM-1000 are not at all the same unit, so the link to info about the VM-1000 likely doesn't apply.
