az_gila
This is for a -6A, but since I am following DWG 19 of the 7/9 plans I thought I would ask here.
Are the locations of the throttle and carb heat control cable critical in the vertical direction.
The -6A is getting to be a hybrid with the newer battery location and heat box, but some of the older -6 stuff is still behind the firewall.
I would like to move the throttle location 0.5 to 0.75 inch lower and move the carb heat penetration 0.25 inch lower.
The engine will be a standard O-360 with a carb.
Since no engine is attached I can't tell if these location changes are critical to cable routing ahead of the firewall - any help would be appreciated.
