JurgenRoeland
Hi all,
I'm scratching my head on the fuel lines installation. I'm trying to find out where the firewall penetration point should be in my case. I will install a IO360 fuel injected superior engine and I have purchased the andair fuel pump and andair firewall penetration fitting. Unfortunatly it comes with little documentation.
Should I use the same location. I saw a copy of OP32 io360 fuel system for rv7 but I have the fuel pump in the cabin and not firewall fwd side.
I'm wondering if I need the firewall doubler if I use the andair BH375 bulkhead passthrough.
and if the location of the passthrough remains the same.
gr from Belgium
gr from Belgium
