walkman
I need to purchase some replacement plugs. I'm running a normally aspirated O-360 and run 100LL exclusively.
I have a little bit of a fouling issue. I'm going to be going 1/2 EI very soon, but I have a couple of bad plugs and want to put in 4 new aviation plugs that I will retain post EI upgrade.
I currently run RHM40E. I was looking for a replacement plug that is fine wire. However I don't find an RHM40S, is the "38" plug being colder going to make any difference?
What is a good plug to use?
Should I have my new magneto harness made up to use "E" rather than "H" ends on the plugs? Is having "H" ends restricting my plug choices?
