eh_v8_tor
Active Member
Finally Buidling a Fuselage, a.k.a. the Hunt for the Elusive F-601-E-1
Hi Guys,
I'm looking for some input from you guys that are just a bit ahead of me.
What do I make the F-601E-1 out of?
This is the piece of 063" 3/4 x3/4 angle aluminum that braces the firewall. It is located horizontally just under the firewall recess on the cockpit side of the firewall. I've found a couple of 3/4 x 3/4 inch pieces, BUT... these ones are 6 feet long. I don't want to cut those because they MUST be for something else!
The F-601-E-1 piece I need to make is only 8 inches long. I won't cut the 6 foot pieces unless that's what we use for making this part. Does anyone remember if there was an 8" or slightly longer piece of .063" 3/4 x 3/4 in the RV-7 Slow build fuselage subkit? I've turned my shop upside down looking for it.
Thanks in advance,
Steve Wolfe
Hi Guys,
Thanks in advance,
Steve Wolfe
