Rallylancer122
Hey Guys, I recently installed an Electroair electronic ignition, and now I'm getting some static on my com radios when receiving. When I shut the ignition off and run on the mag it goes away. I had to run a couple power wires all the way back to the battery and it appears at some point they are running to close to the antenna cables or some audio wires.
Before I tear back into all the wiring, I have to at least check and see if there's some sort of filter I can put on the power wires? I'm pretty sure I know the answer but it doesn't hurt to ask. The battery is easy to get to. The back of the radios....not so much.
