"Simplicate and Add Lightness"
... Purely cosmetic, but I think the rivets and the plane would look better ... filled and sanded prior to painting ... I don't think this would be a violation of the E-LSA thing.
It would look better, but as I read the LSA regs, it is a violation to do this. But regardless, unless you completely grind away the heads and have a flush finish, filling the holes will make virtually no difference to the drag produced by that big head, or to the speed potential of the aircraft (which is limited by regulation anyway), and as someone else pointed out, will subtract from the useful load of the aircraft.
Van is a smart guy (a LOT smarter than me), and has spent a lot of time thinking about things like this. For the RV-12 to be licensed as an E-LSA, it needs to conform to the factory build S-LSA example. If a person wants to customize and go fast, maybe they should consider getting an RV-9a instead.
Sorry, I really don't mean to sound like I'm lecturing here.
I've had many of the same thoughts regarding building the best, most desirable RV-12 possible, but after researching the regs with an eye toward my company beginning commercial assembly of the '-12, I can only conclude that a '-12 needs to be a '-12 with no improvements, at least until it's been licensed.
I'm currently thinking about a Rotax or O-235 powered '-9 for my personal(ized) flyer.
Tom Tyson
Rhino Aircraft
(N512RV - Reserved)
