I keep going back into the bedroom closet and looking at the completed parts I have in storage up there. One part I haven't been happy with is the trim tab. That jig I made to hold the tab tightly against the foam wedges while the proseal set... well, it pinched a little *too* tightly, and there are now depressions in the trib tab skin at the positions of those two foam wedges. These depressions are quite obvious when light reflects off the skin.
So, two solutions:
1) build a new trim tab
2) use some kind of filler to smooth out the depressions.
Advice on option (2)... what would be the best filler, and how well will it work? I would want the lightest thing possible, since I don't wan the filler to significantly increase the weight of my trim tab. I've heard of epoxy products like "microballons"... is this the way to go? Other options?
So, two solutions:
