Hello everyone I've decided to make my side skirts and rear skirts on my RV-6A out of fiberglass and carbon fiber. I went with the following layup; 3 layers of 6 ounce fiberglass cloth and 1 layer of 5.7 ounce carbon fiber cloth. Now my question is do you think this will be strong enough? It is quite rigid but not quite as rigid as the stock aluminum skirts. Next if you have used fiberglass skirts how did you attach them, glue or rivets. Lastly did you use the reinforcing C791? If so how did you attach this to the bottom of the inside of the fiberglass skirting, glue or rivets?
thanks guys,
William
thanks guys,
William
