Iluke
Hi everyone,
I'm currently puzzling over how to plumb my high-pressure FI fuel pump (RV-7) and would appreciate seeing pictures of how anyone else has done it.
I'm using the stock Van's fuel valve and the HP pump that Van is currently selling (the one without a return line).
I'm trying to figure the best layout to get everything to fit under the cover, and it is going to require some fancy tube bending. Os if you have the same set up and could share a photo, I'd appreciate it.
thanks
Ivan
thanks
Ivan
