QuixoteAg
Patron
I'm trying to figure out my panel and I've got several instruments calling for an OAT probe...rather not have little probes sticking out all over the place and just rely on one. can you do that with OAT probes?
Not sure about others, but NO with GRT OAT probe. I suspect it the same for other manufacturers.
On GRT if you connect OAT probe to the EIS, that information will be shared with the EFIS'.
As Mel says, generally no. Most probes are thermistors - resistors of a sort that are fairly temperature dependent. Your device has to supply and measure a current to the probe. If you parallel them, each device only supplies a fraction of the current. If you can do gross re-calibration of each unit, then it might work.
No
As stated above, they are basically calibrated resistors (thermistors, different temps give known resistance values). When splitting the feed 2 different places, you get half (or a portion) of the known value, and so end up with wacky numbers. Garmin solves this problem with a GAD 13, which is basically a small computer that reads the value, and then publishes it on the CANBUS for the other instruments to read. Dynon, GRT all do something similar, basically one device that converts the analog signal into a digital feed that can be consumed by the rest of the devices on the same “network”.
uAvionix AV-30’s have the ability to read the probe directly, but probably in an effort to save money or installation complexity, don’t share the info in any way, so on a retrofit I did in a Warrior, I ended up having 3 probes (2 AV-30’s and an AV-20) sticking out of an inspection plate, but buying 3 redundant probes was still cheaper for that install than ripping out an entire panel or buying all the necessary follow on pieces for a Garmin install.
Some of the temp probes use a temperature sensing chip that varies current with temp. This device would not be compatible with systems using the much less accurate thermistor’s. In either case you can not use 1 sensor with multiple systems.
Thanks everyone - that's what I was afraid of. time to rethink the avionics stack again :)
