Hi all, I have a question about a "factory" inverted oil system. I have an IO-320 E2B out of a Citabria. It has a baffle between the case and the sump. There is a trap door to keep oil in the sump when inverted and a "clunk" on the oil pickup. When inverted, it simply falls over into the oil.
I have all logs, but they do not mention the system. I was told that it was an American/Champion STC. Does anyone have any info on this system? Where can I find documentation for overhaul, inverted limitations, etc.?
I have a Christen system, but I would like to use this, because it is sooooo simple. It will not take up any space (I am building a -4). Any info would be greatly appreciated!
Bryan
Bryan
