DaleB
We’re just finishing up our CI, or trying to. 2011 RV-12 with 400 hours. We sealed up a slow leak in the fuel tank, so before trying to run the engine I put 5 gallons of fresh alcohol free mogas in the tank. Removed the drain from the gascolator and started running the pump to flush out the lines. It pumped about 2 gallons and suddenly stopped dead. Fuse is OK and there is power to the pump. The fans run with the master on. Only a minor drip of gas with the valve open and gascolator drain removed. I removed the baggage floor cover and gave it a couple of sharp taps with a screwdriver handle, no effect. The pump is not making any noise at all that I can hear...
Before I tear into this, what’s the most likely problem? Would a chunk of debris like Proseal that we missed with the vacuum do this? OF COURSE it has to happen on Friday afternoon...
